Diameter, correct
Tooth count, correct
Balance, for the explorer engine that is, correct.
bolt circle, maybe. broncos came with 2 different bolt circle torque convertors. The no longer serviced 10.5" bolt circle which won't work and the 11.4" bolt circle that will work. Get the torque convertor with the 11.4" circle to replace the 10.5" if that is your problem. The correct flexplate (164 tooth, small bolt circle) is an obsolete part for the old balance engines and never made for the new balance engines.
