will i need a drop down pitman
Officially, you don't "need" to do anything to the steering for that lift.
However, no matter how much, or little, you change the suspension height, the same two things are going to happen that would happen with more lift. Your axle is going to shift to the driver's side (trackbar pivoting that way), which is not a huge deal. And your steering wheel will be off-center (draglink extending down). Which IS a huge deal with me. I HATE crooked steering wheels and it's not "correct" to pull the wheel off and re-center the wheel, because the steering box is still off of it's on-center position.
So while you don't absolutely have to have one, I would use one, along with a trackbar bracket.
OR, to get away without either of those, an adjustable trackbar will re-center the axle, and an adjustable draglink will re-center the steering wheel.
That last is a more expensive option, but the adjustability makes it easier to fine tune and get things exactly right.
All pretty much up to you.
Oh, and I'd still go with 7° C-bushings unless I knew that my caster was fine.
I should have just said to do the lift, then check everything to see if you can live with it.
And it can't hurt to check the brake lines too, especially if you intend to wheel it. You can run out of brake hose and parking brake cable quicker than you might think.
broncnaz
X2 more or less. Just remember that most if not all drop pitman arms are for 3.5in or taller lifts so installing a drop pitman arm with a 2.5in lift may actually move the steering off center anyways. So in the end you didnt correct anything. adjustable drag links and trac bars are the way to go. IMO. I think my front axle was maybe 1/2" off after a 2.5in lift barely noticeable and it handled fine.. I eventually went with adajustable trac bar and drag link but mostly because wanted to recenter the axle exactly and i was doing a disc brake and TRO swap so i needed the drag link.
knack
Lift it, then figure it out is good advice.
Other changes you might have made will make a difference too. I added a '76 front axle to a '70 frame with a 2-1/2" lift and a 4X4X2 steering box. After that I ended up cutting off my new track bar drop bracket and going back to a stock pitman arm to get the geometry right and keep things from crunching together when the suspension flexed.
