Windshield wiper wiring
rojo23
Ashland, VA
I am replacing my factory harness with a Ron Francis express harness. Can someone help me identify the factory wiring colors
Thanks for any help
Plug into the factory switch has
2 black wires
White
Orange with white stripe
Green with black stripe
Red
Blue
Harness that runs to the wiper motor
Red
White
Blue
Black
About 8” from the wiper motor plug there is a black wire that rounds to ground and a black with blue strip
Opposite end of harness has
Black and white wires in a connector
Red and blue wires in a connector and a stand alone black wire
Are you sure the Black with blue stripe wire is grounded? Seems like Black W/blue should be for a dome light when they were optioned with it.
Harness would’ve included that whether you got the dome light or not.
Can’t help with the main wiring right off hand, but remember two things that are important here.
Don’t forget that there is (usually) power being supplied to the motor even when the switch is in the OFF position, so that it can park.
And the other is, make sure that your windshield frame is well grounded to the body!
The wiper motor grounds to the frame and will give you all kinds of testing fits if it’s not a good reliable connection.
R
rojo23
Ashland, VA
The black w the blue is for the dome light. I couldn’t figure what else it could be but that makes perfect sense. Thanks
There is a black only wire with a ring terminal that goes to ground
serial car restorer
Yes, I'll restore almost anything...
Western Oregon
Those are both for the dome light.
The Green/black and one of the black wires are for the washer.
R
rojo23
Ashland, VA
So there are 2 wires for the washer pump? I assumed the green/black wire and the other would be a ground
Looks like the orange/white wire supply power to the switch
Are there 2 12v wires going into the switch?
There is a black wire in the socket that I traced and it ties into 2 orange/yellow wires and then goes into a flasher. Is this a ground?
serial car restorer
Western Oregon
Yes, one is the power for the wipers, the other for the washers.
No, that should be the power for the washer. The other solid black wire from the switch goes to the wiper motor.
R
rojo23
Ashland, VA
So looking at the back of the socket
Orange/white wire is 12v
Green/black goes to the washer pump
Black wire is 12 v? This wire is the one that runs to the flasher
On the right side of the socket there are 4 wires
Red white blue and black. They tie into the short harness that runs to the motor
Thanks again
