Wiper Motor Wiring Help
coachbarnes
Franktown/Breck, CO
OK -- I just bought a new wiper motor for my '74. Went to install and noticed the plugs and wiring are different. I've attached a pic of each plug (new and old), along with the wiring colors from each. 1st issue is obviously the plugs are different. I'm assuming I should replace the plug on the motor to match the Bronco harness? The next problem is the number of wires is different. There is a ground wire on the new motor, but not on the original.. I'm ok with some of this stuff, but wiring is definitely not one of them. Any help here on how I should proceed would be appreciated... Thanks!
Viperwolf1
electron whisperer
On the original motor these are the colors and functions.
low speed=white-orange
high speed=blue
park return=black-white
park power=red
What I would do is use a 12v source to figure out which are the low and high speeds. Just touch the 12v to each wire quickly to see if it makes the motor spin. Make sure the ground is hooked up.
The other 2 wires are going to be trickier to figure out. One of them will be grounded when the motor is in the park position. That will be the park return wire. You could use an ohmmeter to see if the other 2 wires are shorted together in the present motor position. If they are, then the motor is not in the park position. Bump one of the other power wires to move it slightly and check continuity again until the park wires become open. At that point one of those park wires be grounded and the other will not.
Let me know if this doesn't make sense.
coachbarnes
coachbarnes
Franktown/Breck, CO
I wish I understood wiring like viper does! Really I wish he was my neighbor!
That's 2 of us! I was fortunate enough to meet him in Moab when I was having a turn signal issue. He grabbed some tools and quickly determined the problem. I was sure hoping he would respond to this one. Viper is one of the true gems of this Bronco community!!!
Hmm, so there was no included connector and contacts for you to convert your chassis-side wiring? Did that come from us? Should have been included unless something has changed since we added the picture and pinout on our site.
Sorry 'bout that.
Since doing my first Centech harness I've been replacing them all with Weatherpack connectors anyway, but yours should have been included if that's one of our motor kits.
Let me know and I'll see what I can dig up on Monday, unless you get it squared away before then.
coachbarnes
coachbarnes
Franktown/Breck, CO
Sorry 'bout that.
Yes sir -- It came from your fine establishment. I won't be messing with it this weekend, so anything you can dig up to help next week would be appreciated. Mucho Gracias!
coachbarnes
coachbarnes
Franktown/Breck, CO
Paul -- I just placed another order. If you can scrounge up another plug to replace the existing harness plug and throw it in with the new order, I would appreciate it.... thanks much -- Scott
coachbarnes
coachbarnes
Franktown/Breck, CO
So as it turns out, I had NOT ordered this from WH! I initially place an order with them for several parts(including a wiper motor) but they didn't have a couple of them in stock so I cancelled the order and placed it somewhere else. I won't mention where I ordered the motor from, but lets just say they still haven't replied to me when asking them to send a matching plug. In the mean time, WH sent me a matching plug and I didn't even but the darn motor from them!!!! I've always been a fan of Wild Horses, but wow! This is above and beyond. I love dealing with these guys!! (as well as the Duff family). Some of the others? umm notsomuch...
fluffybunny
Hopefully someone can point in the right direction on my wiper issue. I recently purchased a 77 wagon that's been rewired with a Centech harness. It appears that it was professionally installed. I installed the wiper motor and as soon as I turn the wipers on it pops the fuse. It shows that the radio shares the circuit so I disconnect the power to it and no change. Is the motor grounded by mounting it to the windshield frame? If so, I'm thinking that it could be a poor grounding issues.
Thanks.
Viperwolf1
electron whisperer
The motor is grounded at the frame but a bad ground won't cause a blown fuse. Look for another problem like bad wiring inside frame or motor wiring wrong.
Did you by any chance try connecting it to power before the motor was installed? If you disconnect the motor and it still blows the fuse, you can start backtracking from there.
JAFO
Beaverdam
With the ignition switch OFF, disconnect the connector up near the motor and then check continuity to ground from each wire that supplies power. You should not get 0 ohms to ground from a +12v supply wire. Do that for both connectors (the one going to the motor and the one going down the window frame. See if something is shorted to ground. That will blow a fuse.
Also, does the fuse pop if you turn on the switch with the motor disconnected? That would mean one of the supply wires is shorting to ground most likely.
Finally, you can check for the supply voltages at the connector with the ignition on, wiper switch on.
Could be a faulty motor.
fluffybunny
I got it figured out. Along the top of the windshield there were two wire looms; one for the wipers and one for a dome light. Someone spliced in the black "Park" wire and the black "Ground" wire for the dome light backwards. I'm so glad I didn't have to trace wires under the dash. Figuring out the wiper arms was a head scratcher for a few minutes. Thanks again.
duffymahoney
I pulled my stock wires out. They were ruined. My wiring kit didn't come with that section. I think it's going to be a royal pain to put wire in there
Teal68
Inlet Beach
Attach a vacuum hose to one opening and piece of string to the other opening and suck the string up and thru so you can use it to pull the new wires. Done it a couple times and works great.
JAFO
Beaverdam
My Centech harness did come with the wiper wiring (and the colors matched the motor wiring, but the wires are marked as well for return, park, etc), but fishing wires up the windshield frame (if that is what you mean about a pain) was fairly easy. Do like when pulling wires for a house, fish one wire down the frame like using a fish tape, tape the new wires to that wire and then pull them all up. Of course this is with the windshield frame tilted forward so you have already fished wires from under the dash.
Hey @68, welcome to classicbroncos!
Yes, that's what they did. And they're a bugger to get up the chase. It helps to be able to push the windshield frame forward to expose the lower hole, but I've heard of some succeeding without doing so.
Either way though, it's a tight fit. You might find a more recent thread about it in fact, because I think i remember a few discussing it just a month or so ago.
I have to ask though, is your Bronco a '68? If so it would not have come with electric wipers from the factory. So while the chase up the left side frame rail may be the same as later years, the hole at the bottom might be completely different for having had a vacuum hose originally.
Good luck.
sprdv1
REBEL
Does the wiper motor wiring go from behind the dash and up through the windshield frame and out at the top left of the frame?
Having trouble going from the inside the frame to behind the dash.
Okay, working the problem-endeavor to persevere.
Welcome aboard...
