Wiper motor wiring question
Hinmaton
Good morning-
I have searched through and found a few posts regarding my question, but have not found any definitive answers to my specific question.
My wipers stopped working, however the washer works fine.
This happened after I removed my dash pad, repaired a fuel line leak, wired a reverse light switch (was 3 on tree, now np435) and put a floor mat in. The dash pad being the most likely culprit if there is any- When I removed the two WS frame retaining bolts, the captured nuts fell away and I was unable to replace the bolts (I have a Krawlers Edge family cage which bolts to the WS frame, so I was not terribly concerned about loosing the retaining bolts).
I didn't realize that the wipers didn't work until the next rain of course, and I spent a few hours trying to diagnose the problem (I only had a 12v tester though and a poor wiring diagram in a Haines manual).
-Fuse is good
-Washer is operational
-I am getting 12v at the switch on the B/W wire and O/W wire (but constant in all positions)
-I followed the wiring under the dash to the connections before it heads up the A pillar ( two 2 wires connectors and a single) and found the B/W wire to have signal on all positions.
-Checked the connection before the motor with the same results.
-I tried jumping 12v to the other wires and nothing happened.
-Fuse still good.
-I tried to determine if one of the wires was a ground (poor wiring diagram didn't indicate well) and killed my tester.
-Found the better wiring diagram (I've attached below) and read through a bunch of similar related questions on the forum and determined that the motor grounds through the WS frame. The WS frame retaining bolts were most likely acting as the bridge between the WS frame and the dash?
-Tried to use jumper wires to bridge the WS frame and the dash and tried bridging the motor housing and the dash; neither of which yielded anything.
-Fuse still good.
-I studied the wiring diagram more and am feeling that I need to re-check the wires at the switch, and the connectors again. Going to the switch I should have two 12v signals W/B and O/W and I should have at least the Red wire (Park Wire) showing 12v in all positions. Right? I swear I saw only the B/W wire showing 12v? which is only hot if the motor isn't parked (which currently it isn't) but I should still see 12v on the red right?
What am I missing?
Are there other tests that I can be doing?
I will mount a hard ground between the WS frame and the Dash, or maybe a dedicated from the motor to the dash?
Is there a way to test the motor in situ? Or the switch?
thanks,
Hinmaton
Hinmaton
Hinmaton
Alrighty then- signature updated.
Hinmaton
Steve83
This shows the wiring:
(phone app link)
Read the caption, and consider printing all the pages for quick reference in the garage. You might even want to keep it in the truck.
Applying 12V to either circuit 57 or 58 should make the motor run. If the key is in RUN or ACCY, it should finish the wipe.
Without the bolts you might have lost the best ground your frame had left. Yes, it's "supposed" to ground through the hinge, but as we've found out many times, the old spot-welded and bolted connections on the body parts of Broncos is not always enough after so many years of paint and rust.
So a quick test (or a permanent one just because there's no such thing as too many grounds) would be to run a short jumper wire (maybe 14ga?) from a body panel to the windshield frame. Maybe one from the body to the dashboard while you're at it.
The last one I remember doing was right there on the driver's A-pillar semi-hidden with the door seal, fender/dash/tub body parts and was not obtrusive at all.
Give it a shot first, to see if you still have a wiring problem. Or if it's just a ground issue.
If it doesn't fix it, well, at least you have a really well grounded windshield frame!
Steve83
Good catch, Paul. I had forgotten about the bolts being the motor ground path.
On Frank's '75, the '88 F150 wiring harness I used included a return wire in the wiper motor harness so it didn't actually use the body ground.
To add one to an original eB harness, run a Bk wire about the same gauge as the other motor wires from the ground-strapped motor bolt through the w/s frame into the dash with the other wires, and to one (or more) of the original dash/firewall ground points.
Also make sure the battery (-) goes to a clean, solid ground point on the inner fender.
Hinmaton
Hinmaton
I did a continuity test on the frame to dash link and I did loose my ground with those bolts. I put a 14awg jumper between them right at the top A pillar as Paul described. This solved the ground issue, but did not solve the problem. The problem is I am not getting power to the motor through the switch, just the rewind wire. With the ground in place, I was able to jumper the motor and see that all three position functions did in fact work.
I tried under the dash readings for incoming voltage, but was having a hard time distinguishing wire colors and ruling out false negatives, so I pulled the switch and determined that wire 763 B-W the ignition side feed wire wasn't delivering any signal and I ran a continuity test, which range out. I'm unsure if this means that I have a dead short or just a good connection without line voltage?
The wire dives into the harness a few inches from switch, so I'm not quite sure how to trace it...
I did notice on the wiring diagram that the washer feed wire ties into the radio harness. The original radio was replace by the PO and I had just removed it last week... maybe it was tied into the wiper feed wire instead and I disturbed it somehow?
It's too cold to keep going- so until tomorrow then-
Hinmaton
Yeah, strange one. But those pesky wiper motors are strange in their function anyway. Leave one wire off or connected improperly and the whole thing goes wonky.
And won't clue you in with most normal tests either!
Well, at least they don't until you let them know who's boss.;D
The washer working won't normally have anything to do with the regular functions of the wipers themselves. Different part of the switch (so the switch can still be bad) and a different part of the harness, going to a different part of the vehicle.
Unfortunately then, one does not indicate much about the other. Other than you're getting power to the switch.
By the way, is this a stock harness and switch? Or replacement stuff?
Hinmaton
Hinmaton
Stock harness that has been scabbed into here and there. I know that the WH H4 headlight harness was added on around the same time as the Ididit tilt column was put in, but it’s old and stiff back there beyond that.
...so I pulled the switch and determined that wire 763 B-W the ignition side feed wire wasn't delivering any signal and I ran a continuity test, which range out. I'm unsure if this means that I have a dead short or just a good connection without line voltage?
What do you mean by range out? Zero ohms/open circuit? This is probably ok, and it's better to check for full battery voltage I think. Well, at least it should be easier!;D
This power feed comes from a splice inside the harness, but ultimately comes from the 20amp fuse at F1 "Heater" in the panel.
I would check that again if you haven't already, and make sure that the contacts are clean, tight, and that the connections on the back of the fuse panel are in good shape.
One way to check the fuse itself would be to find out if the heater is working. If you can get good blowage out of the fan, the fuse and at least part of the harness is good.
Hinmaton
Hinmaton
I meant "rang" out, using an audible continuity tester. 0 ohms, which means it's making a complete circuit, or going to ground somewhere. But there isn't 12 volts at all.
I will check the heater fan circuit.
what else is on that circuit?
thanks,
Hinmaton
Hinmaton
The heater fan works great. All fuses in the glove box are good. I plugged the radio back in just to see- radio works but no juice to the wiper switch. I found a few loose wires looking through the radio slot that are keyed 12v but nothing that looks like came loose from the O-W #763 wire. I guess I’ll look over towards the ignition switch side.
Hinmaton
Hinmaton
Well... between the poor light, awkward angles, faded muddy colored wires and my failing vision; I was reading the pin-out on the plug mirrored. After pulling apart the switch trying to disconnect it, I figured out I have incoming 12v at the two pins. I verified that the switch is functioning correctly in all positions. I tested and found 12v at one of the connectors under the dash before it heads up the A pillar, both the park and high speed wires.
But the motor still is not running?
So it’s either a ground issue or a connection issue. But I did successfully test the motor with a jumper.
I don’t get it...
I’m missing something.
When you jumpered the motor to test it, where did you put the power? Disconnected the square plug up near the motor?
I went through something similar with a wiper motor last year and it was just waiting for one more wire to be connected up at the motor. Perhaps your connector is wonky and not getting a good circuit to where it's supposed to up at that connector.
Check for voltage at the pins when the dash switch is in the different positions. If you haven't already.
Hinmaton
Hinmaton
I did jumper at the square connector right before the motor. I used a 12v source that the P.O. had brought up for a fan.
As far a your next question, what do you mean by checking the pins? Do you mean at the back of the switch? If so, then I did check and verify that the switch is sending signal to the correct wires at the desired position.
Hinmaton
Sorry, no I meant the pins on the windshield frame side of the connector. In other words, the section of harness between the dash switch and the wiper motor. It's seeming that the power is getting out of the switch, but not getting to the motor. You verified that by testing the motor and switch independently. There's only one place left for the electrons to be stymied.
Since you know the frame is grounded, and it's sufficient or the motor would not have worked because it gets it's ground through the frame, it would follow that the wire harness is failing.
So checking the pins on the frame side of the square plug for 12v would be a next step.
Hinmaton
Hinmaton
Well, I figured it out... still only 12v at the motor connector, which means it’s in the harness. Fiddled around with the harness while it was hot and got sparklers up by the defrost opening.
Looked down in the crack and could just see some bare copper. Looks like I tore up the harness a bit when I removed the dash pad. Did I fail to mention that I removed the dash pad without dropping the windshield or removing the dash? I pried out the windshield side screws with a chisel and pry bar just enough to get in there with a short bladed sawzall.
Looks like I clipped two wires in the process.
I was able to fish the harness back down enough to repair the two wires, but tore up the insulation further up the harness in the process. Now the harness is wedged and won’t budge either way.
So I’m going to clip the harness on either side of the A pillar and splice new wire in.
Good grief!
Thanks for all the help everyone.
Oops! Glad you found it and made the fix.
Now on to the next project!
