Hinmaton
- Joined
- Oct 17, 2017
- Messages
- 605
Good morning-
I have searched through and found a few posts regarding my question, but have not found any definitive answers to my specific question.
My wipers stopped working, however the washer works fine.
This happened after I removed my dash pad, repaired a fuel line leak, wired a reverse light switch (was 3 on tree, now np435) and put a floor mat in. The dash pad being the most likely culprit if there is any- When I removed the two WS frame retaining bolts, the captured nuts fell away and I was unable to replace the bolts (I have a Krawlers Edge family cage which bolts to the WS frame, so I was not terribly concerned about loosing the retaining bolts).
I didn't realize that the wipers didn't work until the next rain of course, and I spent a few hours trying to diagnose the problem (I only had a 12v tester though and a poor wiring diagram in a Haines manual).
-Fuse is good
-Washer is operational
-I am getting 12v at the switch on the B/W wire and O/W wire (but constant in all positions)
-I followed the wiring under the dash to the connections before it heads up the A pillar ( two 2 wires connectors and a single) and found the B/W wire to have signal on all positions.
-Checked the connection before the motor with the same results.
-I tried jumping 12v to the other wires and nothing happened.
-Fuse still good.
-I tried to determine if one of the wires was a ground (poor wiring diagram didn't indicate well) and killed my tester.
-Found the better wiring diagram (I've attached below) and read through a bunch of similar related questions on the forum and determined that the motor grounds through the WS frame. The WS frame retaining bolts were most likely acting as the bridge between the WS frame and the dash?
-Tried to use jumper wires to bridge the WS frame and the dash and tried bridging the motor housing and the dash; neither of which yielded anything.
-Fuse still good.
-I studied the wiring diagram more and am feeling that I need to re-check the wires at the switch, and the connectors again. Going to the switch I should have two 12v signals W/B and O/W and I should have at least the Red wire (Park Wire) showing 12v in all positions. Right? I swear I saw only the B/W wire showing 12v? which is only hot if the motor isn't parked (which currently it isn't) but I should still see 12v on the red right?
What am I missing?
Are there other tests that I can be doing?
I will mount a hard ground between the WS frame and the Dash, or maybe a dedicated from the motor to the dash?
Is there a way to test the motor in situ? Or the switch?
thanks,
Hinmaton
-Fuse is good
-Fuse still good.
-Fuse still good.
What am I missing?
thanks,
Hinmaton
