Where on your website or the installation instructions is any this input made available?
I suppose that in so many words, it's not.
Our instructions "assumed" that the end-user is actually looking for a true self-exciting "1-wire" alternator to save some of the hassle of hooking up extra wires, was willing to pay more for that benefit, and would therefore take those instructions at face value and just do as they say. Namely, hook up the one new 6ga or larger charge wire to the truck, and call it a day.
The alternators should ship with the plug already installed and the 2 existing wires hooked up. If that's not the case, let me know and I'll see what has changed at our end.
Sorry about the misunderstanding.
I'm working on some additions now, to the website and the instruction PDF, that will hopefully make those details even more clear.
I ran into the same issue (duped?) by the WH 3G alternator. Definitely not a bolt on conversion alternator with an ASI plug that only has 2 wires !@$%$@.
The whole reason I sourced the alternator from them was for an EB specific conversion. Had I known I was going to get one from Autozone thrown in a WH box....well....
So I ended up buying the proper 3-wire ASI connector:
Wow xcntrk. Duped? Sorry you think so. And sorry too that you were put through so much unnecessary trouble.
Did you ever call us to ask about it? Did someone then give you the wrong information when you did? Or did you just assume we were trying to dupe you into paying more for your supposedly re-boxed alternator?
First of all, we
DON't buy them from Autozone. We get them from a small manufacturer and then install their specially made "self-exciting" regulators to eliminate the need for an "on with the key" wire such as the Red w/green wire in question.
If you somehow did get an Autozone sourced alternator in your kit, well, I suppose we might have needed a quick replacement at some point. Not the usual practice, but I suppose it's possible.
Or were you just using Autozone as a quick example?
Did you also think your connector was defective because of the missing wire? If so, a quick call and we would have happily sent you another one. Or better yet, hopefully corrected your misconception about it in the first place and saved you from waiting for another "defective" connector.
If you did call and still have this misinformation, well that's our fault and I'm sorry we were not able to clear it up right away. But that's what I'm trying to do here now.
As Airmapper said, you do
NOT need to use the old Green w/red wire, like you would with a standard 3G alternator. That's the whole point of our calling it a 1-wire setup.
The new regulator makes the alternator pretty much self-contained, other than the main BAT cable that you have to hook up. It uses only the 2 small wires connected to itself for full function. The Yellow "sensing" wire that should be connected directly to the output stud, and the White w/black wire connected directly to the small plug in the side of the alternator case.
With these two connections, the alternator will start charging once it starts spinning.
As said, the only wire you need to hook externally is the BAT charge cable connected to the battery/chassis.
Any attempt to change the plug and connect to an externally keyed source is an unnecessary step, and expense. And possibly dangerous.
I don't really know if it will actually damage the regulator though. And since yours sounds like it's working xcntrk(?), then it may not be an issue.
Since the terminal inside is probably not connected to anything anyway, that could be the case.
But I would disconnect your "I" wire anyway. If for no other reason than to just see if it still works.
It might be one of those "if it ain't broke, don't fix it" scenarios, but it's really not necessary.
The funny thing here is that for years we tried to clear up the misconception among EB owners that any internally regulated alternator was called a "1-wire" and that when hooking up a Ford internally regulated alternator, you really did still need to connect the different chassis wires to the alt for proper functioning.
Now we're trying to clear up why, when you do actually have a self-exciting 1-wire alternator, you
don't have to hook up those wires!
