Ok cool. Maybe '68's (and earlier) models had a different ground wire than the '71 and later I've worked on more often.
But either way, use them if they're grounds and then make up one of your own long enough to reach the regulator. It's just good practice and pretty much necessary with an externally regulated alternator like ours.
More grounds than necessary is kind of necessary.
Updating the main ground cable and main body ground are good. Adding one from the alternator case directly to the regulator bolt is necessary. Adding more is even better!
For sure while you're messing with wiring and thinking about grounds, add an additional one between the back of the engine and the firewall. Every car and other truck of a certain vintage had them. Broncos got left out in the cold on that extra ground wire so we do ourselves a big favor by adding it. Brings our Broncos closer to the modern world than just about anything else.
Black and Black w/red small wires are typically grounds on our Fords. Unfortunately Ford also chose to use Black w/red stripe wires for brake light switches and the battery power to the cabin on later years, so hopefully they also stopped making grounds with red stripes. And by later years I mean even with Early Broncos.
Luckily the main battery power is a large 10ga wire (larger than most other wires on a Bronco) and the grounds are usually tiny 18-22 gauge wires. So hard to mix them up by size. But using the same colors was not one of Ford's better ideas.
Modern Ford charge wires are still Black with an "almost red" stripe, but it's really a bright Orange-ish color. So they're heading in the right direction.
