wiring and flashers (problem solved)
wesleydax
I may have two issues, Anybody know where the right side marker lights get power from? left works right dont. i have traced wires and with out taking stuff apart cant find where they connect. tested all bulbs and there good
also turn signals dont work. checking voltage the large flasher has 12v on both sides and small one has nothing coming in or going out. which one is fourways and which is turn?
the flasher switch doesnt work could this be part of the problem. it hasnt worked in a while. pull the knob and it comes out.
siderbox
Ok let me If I got this.
Right side marker lights work.
Left side marker lights don't work.
Right side turn doesn't work.
Left side turn doesn't work.
No flashers.
What year is your Bronco?
How long have you had it?
How long have you had these problems?
When did they start?
Viperwolf1
electron whisperer
The flasher with the orange-yellow and blue wires is turn signals.
Side markers get connected to front and rear light harness near the lights.
If it's earlier than '74 the hazard switch is bad. If it's '74 or later the turn signal switch could be bad.
wesleydax
wesleydax
Its a 71 it just started a few weeks ago. We've had it since 71. Can I bypass the hazard switch?
Don't know if I've asked you this already wesleydax (I asked someone recently), but is the fuse panel on your 71 on the floor by the gas pedal (early version) or in the glovebox (later version)?
Doesn't sound like that info will help me diagnose the issue, but I'm curious. And the early models were prone to getting corrosion on the fuse contacts and even the two rectangular firewall connectors. Sometimes simply pulling things apart and putting them back together will clean off enough corrosion to get some things to work again.
Good luck.
wesleydax
wesleydax
Fuse panel is in the glove box. I will try unplugging the harness. I'm going to do some more after lunch. I know the bulbs are good.. I just need to find out where I'm losing power.
wesleydax
wesleydax
Also when I unhook the hazard switch do the connectors need to be left apart or jumpered together? I'm guessing apart
wesleydax
wesleydax
well it turns out i had a couple problems. rear running lights not working was caused by a bad connection made years ago for trailer lights. Front lights was due to corroded connectors under the battery box. apparently this also caused the turn signals not to work. I noticed i need to replace the harness bad. most of the wires are brittle and green. Thanks for all the help
