I've got no brake lights and am totally stumped. Here are the symptoms:
Taillights work fine
Both rear turn signal lights work fine and blink at correct speed so bulbs are OK
Hazzards blink fast and only work on front lights
No brake lights
Brake switch is new and tests fine as in getting 12v power and switching on when brakes applied. No brake lights when bridging brake plug contacts either.
Any help would be much appreciated. Might something be screwed with the column wiring or turn signal switch? I've got to say that of all the cars I have owned, this is the most impossible to see under the dash. My bald spot has increased in size with this problem already.
No brake lights
