Sounds like you don't. Otherwise you would have that extra harness that they mention connected to all the gauges.
Maybe they left it out by mistake? If so they should be able to send you a new one, or you could make one yourself, as it's pretty basic.
Your harness should have one wire clearly marked for it's function like the instructions say to connect to your existing regulator. The separate harness is just some wires with the proper push-on connector for the output of the regulator and little ring terminals to attach to the gauges themselves.
The second post on each gauge is where the sending unit wires go for each particular gauge function.
Nope. Don't assume anything. It states in the second sentence of the instructions regarding the gauges that it "includes a special wire assembly to provide power to each of your gauges..." Additionally it talks about the voltage regulator and says nothing about eliminating it.
So if you don't have the special wiring section, as Centech about it.
But look carefully in your pile-o-parts too, because it's not very big and can hide among the loose parts you're not using.
No splicing needed. It's all in the harness usually. Just sounds like your gauge section is missing and just have not found your gauge power wire yet. Look again for the aforementioned Red wire marked "I Post" and/or "INST PWR" in the dash section.
By the way, your IVR, or "instrument voltage regulator" (also known as the "constant power supply") is not an original type for a Bronco. Ours would have had the single tab in the middle and mounted to the screw in the housing in the middle lower section.
You might even see a hint that the old one was mounted to a certain spot by the clean, then rusty shapes on the housing.
Doesn't matter though, as long as the function is the same and the connectors are what are correct for the harness. Otherwise you either need to make the changes to the connectors, or swap yours out for a correct one like this:
http://www.wildhorses4x4.com/category/s?keyword=instrument+voltage+regulator which will bolt to your cluster in the correct location.
Someone should have a pic of exactly where they go, but again, the location and exact part number are not critical to the function as long as they work the same and the location doesn't cause any trouble.
