does anyone else have a suggestion on what to buy. separate machines or a 3:1.
It really depends on what you are planning on using it for. If you are doing a few parts or projects, the 3 in 1 works ok. If you want more precision bends, find a decent brake. The shear works ok on 3 in 1 but gets iffy on 18 ga.
Like some above said, make sure you bolt a 3 in 1 down solid. Ask me how I know this. For one, if you don't, the frame will flex under pressure and the cast iron will crack. Two, you will turn the damn thing over! I've done both.
I'm good at giving advice but not following it. After repairing and reinforcing the cracked frame, i added a metal brace between the feet and put the thing on casters so I could move it around. Hence scenario number two above.
I still use mine, but only the roller part. I found a great deal on a Tennsmith finger brake and i bought a decent hand held sheet metal shear.
