Would like to bench test...
mnido
my windshield motor that came with my View Finder windshield frame. I have no wire currently installed in my Bronco, but I know coming from the wiper the stock wire colors are: red, black, blue, and white. Can someone tell me how to hook these wires up to for a bench test. I assume one is a hot wire, a ground, and two other hook to a switch ? Thanks ahead of time !
bknbronco
North Metro, MN
Did you find a plug that fits that motor? I looked around in the wrecking yard for a while before I fund the plug. I think its a Suzuki or geo motor. I may have another plug around in my bronco junk bins.
The viewfinder frame was a great investment. I love mine. I glued the glass in for a super custom look. I did have problems with the linkage rubbing and had to space the heims with a small washer so it would pivot more. I think I also had to space the motor out with small plastic spacers because something was rubbing there also. (check out page 5, post 52 in my build thread if you have problems)
I cut my dash pad and installed it over the motor.
bknbronco
North Metro, MN
If you asking about the motor itself....page 5, diagram
http://cdn.wildhorses4x4.com/downloads/WH/5722 11-8-07.pdf
I think its power, low speed, high speed, and a park wire? Actually I think you gota ground the motor itself.
RED is hot
BLUE is high
WHITE is low
BLACK is something to do with lo when washer is on or park???
The switch in the dash also has GREEN for the washer pump
mnido
mnido
RED is hot
BLUE is high
WHITE is low
Do you think it will matter if Black lug on motor is not hooked up to a wire ? I am not running a washer. Thanks !
Viperwolf1
electron whisperer
It won't matter if you don't care that it doesn't park. It has nothing to do with the washer pump.
