jamesroney
Thanks. I did some Internet sleuthing, and edited my post just before you replied.The factory 78/79 Bronco shocks were eye (bottom) and stud (top) regardless. You got one short one and one long one with the 2-shock staggered setup and two short and two long with the quad shock setup. Drove many a counter man nuts, I'm sure. We (I, anyway) almost always converted the frame shock mounts to be the eye config on the top too.
But you are a vehicle dynamics engineer. So I'm asking for your opinion. The asymmetric implementation of the front dampening can only happen because of three possible things:
1. Design requirement. (Engineered that way...)
2. Implementation prerogative. (Operations did it that way...)
3. Marketing override. (Marketing mandated it.)
It clearly is NOT a mistake. And it's not someone scabbing it some years later. Ford built it this way. But why??? I have attached a picture from the Car and Driver 1978 Bronco Ranger road test. You can see that the lower Left side damper is mounted to the radius arm cap, and the right side damper is NOT. This would require the BOM to include 1 "special" radius arm cap, and one "special" upper frame mount, and two different shocks. And that upper frame mount would have been welded on a couple of days before chassis assembly.
@DirtDonk you were right! Staggered front shocks.
@bmc69 Do you happen to know if the Passenger side Quad shock upper frame mount was present in the non Quad shock version?
