Yeah, I have both front and rear but pretty sure I welded whichever one wasn’t there before as part of that Duff kit way back when, so two currently, one rear facing and one front and I actually did have them mounted upside down…but I never got to drive itWell, not with any authority anyway!
I've toyed with the idea of trying front-mounted rear shocks to see if that helps. Just haven't gotten there yet.
I have a bare housing so can put my lower mounts on in any location I need for clearance, but have waited until it's all done to see what's needed.
I believe I have heard here, that some have tried front mounting them and found some other clearance issues. But not sure that's a real memory, or made up.
I believe that as far a performance goes, the Bronco cares very little whether the shock is mounted forward or rearward of the axle. Not sure why Ford made the running change during the '66 model year (earliest Broncos had a forward mounted shock) but it could have been for any one of, or many reasons.
The big thing back then was to mount the shocks of solid axles in staggered formation. One facing forward and one to the rear. For whatever reason, Ford chose not to do that on the rear of our trucks. While just a little later, they did just that on the front of some of the seventies trucks. Including some of the '78 and '79 Broncos.
If I'm not mistaken, for the '80 and later models when dual shocks became an option, if you got a single shock model, they were opposite mounted too. Not "staggered" as we think of them, in a laying-down slightly angle, but still straight up and down. Just for and aft of the front axles. So they did experiment with some.
I'm just not sure what they found.
You can also mount some shocks with the shaft down ("upside down" to some) which will often give you the clearance you need without moving the lower mount at all.
Some shocks, such as Rancho 9000's and large off-road shock counterparts, have very large main bodies which make clearance an even bigger issue.
So the only thing for it is to keep doing what you've been doing with the other aspects of your build. Test fit, re-test fit, then re-re-test fit stuff until it fits and works to your satisfaction.
That's what I'm going to do.
![Face screaming in fear :scream: 😱](https://cdn.jsdelivr.net/joypixels/assets/6.6/png/unicode/64/1f631.png)
Contrary, the Duff MS2020, that’s actually the right way up it seems…although I haven’t receive mine yet, but all the pics show it that way.
Thanks for all the good info!
