- Mar 2, 2013
- 2,660
I just got a wrap trap for my Bronco. I am still working on my Bronco at this point, most of the body is done and the tub, doors and tailgate are on the frame. I have a 3.5" WH lift with their 1" body lift mounts in place. I want to install the wrap trap and longer spring perches to correct the pinion angle before I install my fuel tank and other things later on down the road. I have a heavy cage, 23 gallon tank and will build a heavy rear bumper with tire carrier and jerry can holder I will install later as well. The 435 and dana 20 are installed but no motor yet. It will have a soft top.
My question is : can I figure out how much that stuff weighs and put that much weight in the Bronco to simulate that so I can install the wrap trap. Does it really matter or is there enough adjustment in the bar to compensate for some movement of the suspension as far as rolling weight goes?
I tried to read some posts about it but didn't find exactly what I was looking for.
Any help would be appreciated. Thanks in advance!
