Mark1911
- May 14, 2017
- 174
Looking from the folks who "have been there done that".
What I have is a 302 that was in my fox body, this engine with manual transmission and 3.88 gear was a hoot to drive and dependable, the engine has been on my shelf unused for approx 25 years and now in my Bronco. It runs great, but is now backed up with an AOD using a 2000 stall lock up converter, 4.56 gear and 285/70/17 KO2 tire
It is Fords RHO 302 from many years ago that came equipped as follows:
302 block
SVO aluminum cylinder heads
B303 roller camshaft (ok no laughing)
1.6 ratio roller rocker arms
9.1 compression (I believe)
GT40 tubular intake
A9P computer
70mm ACCUFAB throttle body
75mm Pro-M Racing calibrated for 19lb injectors
BC Broncos shorty headers
2.5" exhaust from headers to 3" "Y" collector with 3" exhaust, all stainless mandrel bent tubing
Issue I believe is the camshaft, engine runs great but kind of a dog until higher RPMS as to be expected with the B303.
So, the question is what camshaft would the been there done that experts recommend?
I have seen Comp cams 35-308-8, Comp cams 35-349-8 and Howard's cams CL221275-12S
I now am looking for more of a nice driver with good performance, I don't care anymore about rompity romp cams, too much drama with drivability.
Hopefully this provided info is enough for an educated decision.
Thank you.
Mark
302 block
GT40 tubular intake
A9P computer
Thank you.
Mark
