I've been through every past thread I could find to try and figure this out, but I'm stumped. Plus I'm a noob to Broncos and auto mechanics in general, but have been enjoying tinkering around after spending hours on this forum and watching youtube videos.
My latest project was the voltmeter mod to replace the alt gauge, since I upgraded to a 3g alternator. I followed Steve83's awesome guide and after a few hours, voila, I had it installed in the cluster.
While I was at it and had the cluster out, I also swapped in a new IVR, since my gauges have never worked. I used one of the Scott Drake constant solid state IVRs. I hooked everything up and all of the gauges finally worked (awesome!), plus well as the voltmeter was working (I just soldered a wire from the positive post of the gauge to the 12v input of the IVR). The only problem was that while the gauges were working, all of the cluster lights were on: both turn signal lights, as if the headlights were switched on, plus the red light at the top (high beam light?).
I have an American Autowire harness that was installed professionally when I bought the truck, so I checked the manual and saw that the ground wire on the diagram below was not connected to anything and the terminal end of the wire was taped off (click the thumbnail for full size).
I figured that must have been the issue so I just connected it to the negative end of the new voltmeter since it's a long post and was easy to reach, which contacts the housing anyway, so it seemed like it wouldn't be a problem. When I cranked it to see if that did the job, I heard a pop from behind the gauges and they all went dead and the cluster lights that previously just stayed on all went off. I disconnected that ground wire and nothing, so I assumed I must have blown the IVR and that was why it was taped off to begin with, who knows???
At that point I was pissed, so I just ordered a new IVR on Amazon since have Prime and wanted it ASAP. Here's the one I got: https://www.amazon.com/gp/product/B000IYU9MC/ref=oh_aui_detailpage_o02_s00?ie=UTF8&psc=1
So fast forward to today, I swapped in the new IVR and hooked up everything except for the voltmeter (actually everything was still hooked up, so I just plugged the two wires into the IVR). I also added a new ground wire to the cluster housing; figuring that might have been the problem last time. After my last experience, I tried it out first without the new ground wire attached to anything. The oil and temp gauges spiked, fuel did nothing, and again, all the lights on the cluster came on. So then I hooked up the new dedicated ground wire that I added (not the one from the harness), and the lights went off, temp and oil gauges went to zero and fuel just stayed at zero. Just for the hell of it, I even connected the damn random ground wire from the harness that I think messed everything up before, and although I didn't blow anything this time, it ended up the same as just using the dedicated ground.
Here's a short clip showing what I mean in case my explanation is too garbled. Halfway through is when I touch the new ground connected to the back of the housing to a screw on the dash. Strangely enough, a few seconds later, after the video ends, all the lights come back on and the temp and oil spike again: https://youtu.be/2Nr71s1bnws Pay no attention to the voltmeter, it's not currently powered.
Although I doubt it has anything to do with it, just to rule things out, I did install a battery cutoff switch in the glove box. So now I've got the negative cable running from the battery terminal through the firewall to the switch, and another cable going from the other side of the switch through the firewall to the engine block, and then from there to the frame. I was thinking it wouldn't hurt to run another wire from the switch to the underside of the dash, but haven't done that yet.
My novice self figures this issue with the gauges is either still some problem with grounding, or possibly I need to try to mess with the little adjustment knob on the back of the IVR. Hopefully the experts here can point me in the right direction because I'm about to start throwing crap around my garage if I can't get this figured out.
