Yet another Gorilla Warflare install question-
XT700
Brownsville
Planning to replace the Bushwackers with Warflares tomorrow but have a question about the rears. When I hold them in place and an inch down from the body line I can't seem to get the section that conforms to the rear body line to match up. It is above the body line and leaves a gap, is there no way to avoid this? Would be great to see some pictures of that area. Here are a couple pictures of the fronts installed with the Bushwackers still on the rear. Planning to replace the silver screws really not happy with the look of them.
Thanks, Walt
SaddleUp
Vancouver, WA
Heat it up in that area with a heat gun (I used a small torch but be careful not to burn it if you do) to soften the plastic and then put a screw right in the middle of the bend in the flare. Done this way it can still be seen but unless someone is looking for it they will never know it. The flares are actually set up for a regular opening and after stretching them for a larger cutout this is the result.
Scoop
Bronco Old Fart
Cuchara, CO
I installed Warflares on a friends EB and since it's pretty much a trail rig we left the gap. We installed them just as you said with the top 1 inch below the body seam. I have seen others mounted this way and then use some closely spaced zip screws to force the flares to conform to the contour. I think just leaving the gap looks a little "less bad" than trying to force it to fit! I have not seen a real good solution for this.
EDIT: The heat gun idea sounds like it will work.
tasker
all knowing of nothing
NH
It must be running then Walt? Can't wait to see it move!
Mark
Bronco Klutz
NW Indiana
I agree. On mine, the screw spacing didn't line up with Saddleup's apply heat idea, and I did not want the screw spacing to be off, which I thought would look worse, so I left the gap, which isn't that large and doesn't look bad. You have to look right at it to notice it anyway.
XT700
XT700
Brownsville
Installed the rears this morning, was able to place a screw at each problem spot and then do my spacing from there. Came out decent, not ever going to be a show rig so I can live with it. Problem is now it looks like I need a larger set of tires.;D
XT700
XT700
Brownsville
In this picture it looks like it could fit bigger tires.
Madgyver
Bronco Madman
These are not warflares but I had the same problem going up to the bodyline so this was my solution to the gap.
XT700
XT700
Brownsville
I think it looks awesome.
Thanks, real happy with the overall look. Here is a picture taken 2/5/2006 and another taken an hour ago. I'll be posting a bunch of before/after pictures on the chat forum when I get a chance.
Madgyver
Bronco Madman
Hard to see, is it bodyfiller?
Here you go, I used part of the fender with the bottom ridgeline that I cut off and welded it to the existing fender after a mock-up with the JD flare. I cut another piece of metal to cap it. Welded it in place. Rage to bodyfill and smooth.
XT700
XT700
Brownsville
Wow!! That is a great solution, especially if they were going on a show rig. Of course I've seen the pictures of where you take your rig.:eek: That is one sweet looking Bronco.
deltarat
Drew,Ms
Will it fit correctly if you didn't need the opening up to the seam to fit your tires? If you lowered it, would it stick out the bottom and have to be trimmed off?
XT700
XT700
Brownsville
Good question, I never tried them that way since I wanted the extra clearance. My suspicion is that they would fit to the contour and not need to be trimmed. If you look close you might be able to see that mine are up above the bottom of the quarterr by a small amount.
Mark
Bronco Klutz
NW Indiana
Nice!
Very inventive attention to detail.
XT700, Your rig is looking great!
