[quote author=jpoore link=board=5;threadid=20580;start=0#msg159694 date=1060301783]
Does the 205 come bolted to the ZF from the factory??? (just for my info) sorry to hi0jack
No, Ford used only the BW cases by that time (and I think NVs of late). I think Dodge carried the NP205 as an option into the 90s.
From what I have seen, you ditch the NP adapter and bolt the TC directly to the tranny. This is why you must notch the tranny. Normally the adapter is used with the TC and it has the nessessary clearance.
My $0.02: A D20 adapter runs ~$500. However the output shaft can be marginal, so figure another ~400 for BC's output shaft. Now you have a $1000 D20 (assuming you already had the TC).
The NP205 is damn near indestructable. The gear ratio isn't great, but you can bolt up a NP203 doubler for ~$700. These are bullitproof too. So-> ZF+NP203+NP205= bad ass drivetrain for ~$2000.
Hope I'm not missing anything here...
JP
[/quote]
jpoore, you say the NP205 won't fit but then you say it will. I am not sure what BW means yet either. Are you saying a later model NP205 from a dodge will work and not the Ford unit? Do you mean ZF+NP205 or NP203 would be a good choice? thanks
