It hit the dash in my Bronco. I bought the kit from JB Fab and bent the stainless rod some. I am waiting till it is all back together again to bend it into just the right location.
Thanks. I thought that I had read it hit the dash. Might eventually have been your post. I was thinking of going with JB FAB too if the stock ones didn't work.
It comes close but mine didn't hit. You can put a JBFab zf shifter on it and bend it any way you'd like to fit if you think it comes too close to the dash.
I just installed my short throw shifter. I would report on how it is other than the transmission and T-case are just sitting on the ground in my garage. I can tell you that it is a considerably shorter throw, but without the dash and body it is tough to say how much better it is.
A simple fix that I have seen used by some on here is a piece of flat plate bolted to the shifter and then the handle bolted to the plate farther to the rear, it can also be angled toward the back.
