If you drive a Bronco with burned up wires.... you might be a redneck!!!;Dnecessity is the mother of...redneck punch lines
You can get by without the resistor if you only run the engine for a short time. Dunno what "short time" is, but the resistor wire is there to limit the current to the coil. If the coil is designed to run with the resistor wire and you eliminate the resistor, the coil will get too hot and fail. You can buy a ballast resistor (the equivelant of the resistor wire) at most auto parts store. Just mount it on the firewall. The stock resistor wire is 1.30 to 1.40 ohms. 16 gauge wire should be plenty.can i get by without the resistor wire, just regular wire for everything? what guage wire should i use?
OK, so, like I mentioned, use 904 as the trigger for the fuel pump relay. Also, use 904 (hot in run) to go to the " I " terminal on the 4G. Also, need that big-a$$ wire from the B+ (BAT) connection on the 4G to either the battery positive connection, or to the BAT+ side of the starter solenoid. Also, don't forget the jumper fromthe B+ (BAT) connection on the alternator to the " A " terminal.Using a relay to power the fuel pump. Also, since it is a 4g, internally regulated, do i need a voltage regulator?
The coil should not be connected as shown. The coil gets power from the C connection with the key in the run position. The " I " connection on the starter, that looks like it's connect to ground (can you say "More melted wires") should be connected to the wire going to the coil, but after the ballast resistor. Really shouldn't use the same wire for power to the coil as the one to the I connection on the alternator. Run that Red/Green wire all the way back to the C connection on the ignition switch. Make sure the blue wire has a ballast resistor in it. Remove the jumper at the ignition switch from C to S, and add the connection from the starter solenoid I terminal to the coil.This has got to be a stupid question: If the coil is connected to both the C and the S, what prevents the power from backfeeding the S line after you release the key from start? Diode?
Yeah, actually that looks pretty good. Might want to consider putting a fuse in the red wire going to the relay to fuse the fuel pump. And, just on a practical note, on my 3G conversion, I ran the output of the alternator to the BAT+ terminal on the solenoid, only 'cause it was easier. I just used a big ring connector on the end of the wire. There's only a 12" battery cable from the positive battery post to the solenoid, so I figured it was OK.Like this?
