Jess Luvs 2Romp
The reason i ask, is that i'm a tight time and money reserve... will the 4 drum breaks cut it?
thx, jess
thx, jess
Mr Joe said:I'm running 35's with drums and a booster. Stops nice, but I haven't run down a mountain yet (fade is likely).
72bronco said:I'm a big believer in safety being the highest priority. For what you will spend for a set of quality brand tires you could fund a front disc brake conversion.
I think your priority should be on making your vehicle safe first. If you've got the money for tires then you've also got enough money for better brakes instead. Ditto for a roll cage. If you don't have a good cage then I'd forgo spending money on anything else until you have one of those too.
Jess Luvs 2Romp said:thanks for the info guys.
What about snow or just really cold conditions? Any issues with drums there?
And what about drum replacement parts, so they still make them for the bronco?
thx, jess
72, I don't disagree that safety should be a high priority, but everyone knows that a lot of what we do to our EBs makes them less safe. Lifting raises the center of gravity, running anything other than state-of-the-art radial tires (I run Swamper TSL/SXs) greatly affects street traction, etc. etc. Everything is a tradeoff.
If front discs are great, than we should all install 4 wheel discs because they're even better. We should never lift our vehicles. We should install more than a simple lap belt that came in EBs. Not trying to start an argument, but vehicle safety is a complicated issue.
