...Some give us a run down on cost of using them ..
..How much is the machine
..How much is the wire
...How much is the flux coated wire
...AND HOW much is the bottle ..and the gas.. and do you have a rent to pay on the bottle.
....That may be what I like most about my ARK stick, it only cost when I pick it up.
...Will the Migs weld aluminum.
...And what welder is use to weld the Barrels to the block on a TC gun.
...I just had to add that last one.
MM251 $2000 out the door
40lb spool of solid wire- $40-$45 (lasts a LONG time)
40lb flux wire- $120 if i remember right (I don't use flux core, if I did need it for some reason I could just get a 10lb roll to do what i needed)
Bottle $40 lease for the year. Refill $70 for a BIG bottle, lasts 4-6 months with heavy use.
If you are not using the Mig is only costs $3.33 a month, and with the welds a Mig does, it is worth every penny for it to set and wait for me
My welder is set to accept a spool gun, just plug it in. Can put a 2nd bottle on it for welding Alum, the welder automatically switches bottles depending on which lead you pic, up. (I don't have this set up yet, but will, alum spool gun is about $350 give or take for used)
For the barrel block I would say a Tig welder with a mild steel filler rod
Or if really needed I could fire up my old MM135 and get after it, and not worry about it at all.
I did take the courses at my local Jr. College, 4 full term classes, Safety/Basic Stick, Mig, Tig, Advanced Pipe, to get level 2 certification (I think that is whay my cert says
) Fun course and the instructor here was awesome, 30 year pipe line welder could weld stick with his eyes closed better than I could with my eyes open
-Hijack Off-
