Hope all is having a good day! In need of a little information, if I buy a Front brake change over from drum to disc on my 74, do I just buy a kit and put it on or is there more involved??? My Bronco is stock height?
Bushings.....Yes kind of......but probably not what you thinkThank you for replying, any help appreciated, but I heard there's bushing that will have to be replaced , an alignment, I'm just trying to figure out how much of a rabbit hole I'll be going down?
Thank you for replying, I'm not much mechanical so I apologize but if I use a complete conversion set from say Toms, I'll need these tie rod tapered sleeves with new bushings to complete the job or is it only needed if I use brakes from a 76-79??Bushings.....Yes kind of......but probably not what you think
https://www.wildhorses4x4.com/product/Tapered_Sleeves_for_F150_Knuckles/Custom_tie_rods
These sleeves are used so you can install your stock 66-75 tie rod and drag link after you convert to front disc brakes from 76-79 F150 or 78-79 Bronco. They are needed because the tapered holes in the bigger knuckles are larger. The sleeves bring the hole size down to fit the stock 66-75 tie rod.
Got mine from the link above. I sourced all my own parts from a 78-79 Big Bronco. Not sure if the kits come with the tapered Sleeves or not.
Tim
If you don’t need/want all Ford parts just do the Chevy conversion kits that the vendors sell. They don’t require new knuckles.Hope all is having a good day! In need of a little information, if I buy a Front brake change over from drum to disc on my 74, do I just buy a kit and put it on or is there more involved??? My Bronco is stock height?
It' been a LONG time since I've looked at kits. Maybe an all Ford kit isn't sold anymore? I though someone was selling one. Maybe that dried up. And yes the all Chevy conversion doesn't need the tapered sleeves, Only the Ford F150 and Big Bronco knuckles need them.If you don’t need/want all Ford parts just do the Chevy conversion kits that the vendors sell. They don’t require new knuckles.
BC Broncos and Duffs both still sell kits that use repop Ford stuff, but for what I think the OP has in mind, it'll just be knuckles out so you don't need to worry about the tie rods or knuckle sleeves, etc.It' been a LONG time since I've looked at kits. Maybe an all Ford kit isn't sold anymore? I though someone was selling one. Maybe that dried up. And yes the all Chevy conversion doesn't need the tapered sleeves, Only the Ford F150 and Big Bronco knuckles need them.
Tim
I think Duffs has the Monster Brake Kit with all Ford parts still (except Master Cynlinder). I did that a year ago which included new knuckles.It' been a LONG time since I've looked at kits. Maybe an all Ford kit isn't sold anymore? I though someone was selling one. Maybe that dried up. And yes the all Chevy conversion doesn't need the tapered sleeves, Only the Ford F150 and Big Bronco knuckles need them.
Tim
X10.. front discs for sureI've used the chevy style kit on several Broncos. It works just fine. The biggest advantage of the all-Ford conversion is the larger hole in the knuckle which allows easier installation of bigger axle U-joints or Super Joints. You only really need these if you plan on off-roading a lot and will be upgrading your front axles..
That said, I highly recommend doing a front disk conversion. Much better brakes. It's not a deep rabbit hole!
After doing any work with the knuckles you're gonna want to check your alignment afterwards.Thank you for replying, any help appreciated, but I heard there's bushing that will have to be replaced , an alignment, I'm just trying to figure out how much of a rabbit hole I'll be going down?
This kit is probably the chevy conversion. (I've not looked at it). If so, there is some interference between the knuckle and caliper. The grinding is minor - not major machine work. You could probably do it with a Dremel. The all-Ford kit should not require any grinding.I noticed with the JD Master Disc Brakes products, there's grinding to be done, I live very rual, small town so to speak, getting extras done is pretty ruff! I like their products but looking for power booster master cylinder to disc brakes with out the major machine work needed. Does anyone have a product that they'd recommend that's works really well with my 74/ Dana 44? Thank you for any information that can help me decide!
Thanks for the update!This isn't necessarily "machine" work to get the clearance for the GM brake kit. Side grinder or possibly even a bench grinder would do the work needed.
Had a boss years ago that worked for the USFS in Yaak. Took a guys weekend trip down the Yaak river, flipped the canoe and lost his guns and fishing gear. It was a 1959 Herter's fiberglass canoe that he had mail ordered and was delivered on the train. I bought it from him and just sold it a couple years back.
I was looking at the Ford kit, I'm thinking they all require some type of grinding, I sometimes wished over a up with a phone in my butt so I could get to all this high tech!This kit is probably the chevy conversion. (I've not looked at it). If so, there is some interference between the knuckle and caliper. The grinding is minor - not major machine work. You could probably do it with a Dremel. The all-Ford kit should not require any grinding.
They are pricey but I'm finding in my situation being rual, out in the sticks of Montana, it's a good way to go! Thank you for this information, ?, Can you use them on a Ford kit?Here are some pre-ground knuckles for the Chevy conversion. They are pricey, but new and already have the grinding work done, and new ball joints.
https://tomsoffroad.com/parts/69-75-ford-bronco-pre-ground-dana-44-knuckles
