Just changed the filter on my c4. Obviously drained the fluid out of the pan. Chilton says that you should add 3 qts after the change. I added the three that it recommended but it is not engaging any gear. I suspect that it requires more fluid but would this cause it not to go into any gear?
I am confused...
I am confused...
