My bronco is like Frankenstein's monster, its made up of a bit of this and that. 74 frame, 77 rear and front ends, 66 liftgate, all new body, lots of parts left over from the original that I have tried to rescue.
I am currently working on getting the doors installed. So far I have installed the weather strip, latch and latch rods, handle, lock and glass.
My doors fit and have nice, even gaps which looks nice but I can only close the doors when I slam them super hard, then I have to reach into the cavity of the door with a screwdriver and push a lever on the latch to get the door open. It is so tight that I think if I open and close the doors a couple more times I will bend something. Here are ten things I did to fix it, plus a few questions at the end.
I am not saying these are the right things to do, yours might be different. This is what I did.
1. Trim door panels – The edge of the door panel was hitting the hinge when the door closed. You can see the paint dried funny where the panel was touching the wet paint. I think it was going to crack and buckle the panel given a bit of time. I used a die grinder to trim it and now I have good clearance but the paint is messed up. The pic looks like I cut ¼ inch out but I only cut about 1/16th or so. So its good and bad. I guess I am going to get a small paintbrush and put some primer and leftover paint on. After staring at it and swinging the door back and forth fifty times, that took thirty minutes to fix.
2. Flip straps – My door straps were installed wrong and the strap tab on the door was buckling the adjacent body panel edge so that was an easy one. Two minutes to fix.
