Here's a few..
Thanks for those pics, that helps. As far as the gasket you mentioned, do I get one for the tail adapter or the transfer case, if it matters.
And what is the plan for the twin stick setup? Are you going to have to remove those posts that are on the side of the tail housing and am waiting to see how much has to be removed when you get the twin setup?
Yes, just the stock tailshaft to T/case gasket. The twin sticks mount to those towers you mention. So, they'll have to remain. It's going to be a while before I get that far, but I'll certainly post the pic's when I do. Take a look at JB Fab's website for a bit more info.. Others have installed them here, a search may turn up more info..
I know way back in your build you stated you used black sealer primer. What kind was it and was it rattle can or did you shoot it? I was planning to do mine satin black with gloss black accents...I didn't realize I would find some inspiration from someone on the east side of the state.
Pulled the motor today and need to order motor mounts and some other things on Monday. Getting the new motor ready to go in and it looks like I might have to swap lower intakes. The one from the 99 mountaineer does not have a port for one of the sensors, I think it is the AIC sensor.
Thats an IAT, Intake Air Temp, sensor. Probably exactly what you thought it was, i just hadnt heard the acronym you used. If you have both engines, I guess swapping isnt a bad idea. Depending on the harness you intend to use, you may want to move it though. What engine is that in the 1st pic? The second is the '99, I'm assuming.
Did you use the Sherwin Williams paint on everything or did you use something else on your inner fenders and underneath like por15? Did you just spray it in your garage with an hvlp sprayer? Sorry for the simple paint questions while it looks like you are busy with an engine swap.
The motor I just took out looks to be an 80's rebuild with fuel injection on it, not sure what the donor was but thought it was from an explorer. Yes the '99 is the second pic.
I thought it was called air intake charge = IAC but I see where IAT would be correct.
The IAC is actually "Idle Air Control" which helps to control idle speed. The '99 will have the IAT in the Mass Air. But, what harness do you intend to run? You still have an option of running the IAT in the air cleaner, if you want.. But, having both, swapping might just be as easy as anything else.. Especially if you want to change gaskets before the install.
