joshforrest12
Newbie
- Feb 21, 2021
- 16
Well little update, got the axles narrowed to where I want them. Waiting on axle shafts to come back from Dutchman's. I narrowed the front sd60 8 7/8 from the long side to have the radius arm brackets line up perfectly with the frame. The rear dana60 I got came out of a 83 ford truck. I narrowed that 2.5” each side. So that puts my axles at 60” each to fit perfectly under the bronco. I'm going with a 5.5”-6” lift on 40s. Ori struts front door no need for sway bars or shocks. Rear I'm running leafs for now and then moving to ori struts later. Mainly for cost right now. I'm already 13k into this build. Full lockers front and rear. 4 link from suspension with traction bars in the rear.
