- Jun 8, 2010
- 2,145
I thought I'd do a write up on my experience with narrowing a full width housing for my 73. Hope you kind folks don't mind.
3-19-2020 EDIT: I uploaded some video of some more recent work on a housing. https://youtu.be/wK0HuaWsF1I and https://youtu.be/QaESeMNzPi4 Now back to regularly scheduled posting.
Background: Last year just before OCBR, I finished my explorer 5.0/4r70w/d20 swap. However, with OD and 3.50 gearing I can't useOD unless I'm cruising around 55. It takes too much to push the brick thru the air at 65-75 where I like to drive. So I've been needing to regear, knew it would come, and now I'm there. But before rehearing a 28 spline rear, why not build a 31 spline? I bought shafts for it two years ago for Christmas so let's put them to use. I am going 5.13 gears for two reasons: 1) to self regulate my speed on the hwy (we all know no one should drive an EB the way I do). And 2) I rose with Bubba at prerun a few weeks back and WOW! I want some of that! As for lockers, I've got a spartan in front, and since I REALLY want an air locker (e locker if one comes available), I'm going to put another Spartan in the rear. And for the record, I've recently bought 35's to go on it.
I went round and round with going full width in my bronco, but having already bought shafts and, recently, gears and an install kit for the low pinion, and finding how much more the high pinion gears cost, plus a restocking fee for the ones I would return, plus the extra work of rebuilding my 1 ton steering linkage (and if you pull the front axle out, you might as well stretch the WB a little, and throw on some homemade long arms, yards yards....) I don't plan on beating my truck hard on the trails, but I do intend to go where I WANT to go. All the above can come later as needed.
So this build is using some BB 1/2 bolt ends from quick performance, which I just, while typing this, got a notice that they are waiting for me right now in the mailbox. I have already cleaned up the old spring perches and shock brackets. Time to get started. So here's some eye candy.
Just for yalls''' information, in the future I think it'd be cool to build a homemade double dana 20 (formerly known as the cold duck), but mine would be build so the shift rail is on top so it won't leak. I figure the difference between length of front and rear drive shafts MIGHT allow them to swapped to make up for the added length of the doubler setup. (Man, I'm getting all kinds of key words into this first post!).
Until next tim! (I need to do some work now!)
