I am knee deep into narrowing a 1977 f100 rear axle to stock EB width. the f100 axles have set20 tapered roller bearings. I have read that the retainer plate creates the preload on the bearing. I have the QP axle ends (big bearing old style) and as I understand, it will accept either set20 bearings or the sealed roller bearings. It seems in most applications, such as a front axle hub and the carrier and pinion bearings, tapered roller bearings are in pairs. Since they are conical races, the thrust is only resisted in one direction. so when used in pairs, everything is held together. If the thrust force on the axle is pushing the axle shaft into the housing, the set20 bearings are loaded resisting the thrust. What is resisting the thrust if the force is pulling the axle shaft away from the housing (tapered bearing unloaded)? the retainer plate will prevent the axle from falling out, but does the inner race rub the retainer and/or seal? I would think this would cause a lot of wear. The old style sealed roller bearing is easy to visualize and makes sense. while the roller bearing does not resist side thrust as well as a tapered roller, it does resist load in two directions.
Everything I have read on the interwebs says the set20 bearings are the heavier duty bearing, they work, and I am probably overthinking it. Right now I am planning on buying the 1976-1977 31 spline EB shafts from WH with Timken set20 bearings installed. The only axles I can find with the sealed roller bearings are from Bronco Graveyard, but they are out of stock right now.
To anyone who has done this, am I on the right track? Let me know what you think!
