Project: 76, Orange Special Decor
gnsteam
gnsteam
Lincoln NE
The mounting bracket for the large grey Trans plug may contact the body when you put things back together... You should leave it loose from the trans. I believe I had to have to modify all of mine even with the 1" body lift. Some were just simple bends, two were shortened. Just an FYI...
Great work by the way ;)
Thanks 904, I will loosen it and tie it back against the trans, before setting the body back on.
