I did a combination of a leaf spring overhaul at a great shop in Austin with some added height plus an add-a-leaf to get to two inches in the rear.
Sounds good. No generic way to tell then if the angles are still good, or would have changed substantially.
These days with the new spring packs we just "assume" (but from experience) that almost all 3.5" lifts will require a 6° shim and probably 80% of the 2.5" lifts will too. But with just 2" and a different method of lifting, only directly checking your angles, after the rig is back on the ground and at full weight, will you know what is needed.
The front shaft will bolt up but won’t turn, the back won’t bolt up, so I have 4 degree radius arm bushings and the 6 degree shims on the way.
Why won't it turn? U-joint bind? If so, then adding 4 degree C-bushings is just going to make it worse. Or are you replacing some existing 7 degree bushings with those 4's? If so, then that might be enough, but if you're binding now you may need more than just 3 degrees more to be in the safe zone. Will you be wheeling this rig, or just running around on the street?
Is the front shaft a single-cardan as well? Or just the rear?
I need 4 new u-joints at this point-before I spend that money I’d like to know if I’d be better off replacing the shafts.
Yep, good to find out first. Is the rig back on the ground at this point with the full weight compressing the suspension? Did you measure between the axle and frame to verify the exact amount of lift over stock?
I made the wild assumption (having no experience with the double cardan shaft) that you could remove the double cardan bits and bolt the single u-joint up to the D20, hence shorter.
The end cap of the shaft is completely different and the single-cardan and double-cardan yokes are fully welded to the tube of the shaft. No simple swapping, but if lengths permit, it can be done with the same shaft.
However it really only works in one direction. The shaft's tube is longer on a single joint shaft because the yoke assembly with centering ball of a double-cardan is significantly larger than the standard yoke. So it's relatively easy to convert a single to a double, but not the other way 'round.
At some point it's just cheaper and quicker to buy a new double-cardan shaft and sell your single to someone else.
But be aware that the transfer case yoke is different too. The output yoke for a single vs a double is a different shape and size and design. You can't just get a new shaft and bolt it to the old yoke.
From our company, you need three parts from this page:
https://www.wildhorses4x4.com/category/Early_Bronco_Driveshafts
1. The shaft of your choice and length needs.
2. The yoke #8596
3. Driveshaft bolts #8582
You'd only need new u-bolts for the differential ends if your old ones needed replacing. Otherwise they're the same for both shafts because you're not really changing anything at the differential ends.
Not excited about replacing u-joints that often.
You won't need to if the shafts are lined up properly and your need for extended travel is not great.
Nothing wrong with a single-cardan shaft that millions of vehicles have not proven out already over the centuries. A double-cardan simply gives you some added leeway in use, which is why Ford chose the more expensive path, while other vehicles got along with the single-cardan setups.
Either way, your pinion angles, shaft angles and shaft angles need to be matched accordingly. The angles are not the same between the two types of shafts.
But once dialed in, your joint life will be just like anyone else's unless your use dictates something else being needed.
