Why don’t I have a double cardan rear drive shaft?
cldonley
cldonley
Robinson, TX
After looking at this thing over and over and re-measuring, I have determined that my actual aft pinion angle on the D20 is 1-1/2 degrees DOWN toward the rear end. Still an unacceptable angle.
Perhaps. But with a double-cardan shaft on the way, the angles no longer need to match each other. Rather the rear angle needs to point upward just below the imaginary centerline of the driveshaft once installed.
I would call it very hard to measure at this point, given that the shaft does not start to go down towards the rear end for a few inches aft of the transfer case yoke. Making it perhaps not impossible, but certainly mentally fiddly, to determine the proper angle and shim size if needed.
But it'll be cool to see how close your measurements are, or if they're right on the money once the new-to-you shaft arrives.
If that 6-degrees up-angle is relative to the ground, I'd agree that's a bit of a low angle and will need some raising before the new shaft is dialed in.
paul
armynavy17
Not sure if it'll apply to you, but keep in mind shims can be installed either direction, adding to or subtracting from the angle of the pinion.
cldonley
cldonley
Robinson, TX
I was considering that. I’m beginning to think I won’t need them at all with the double cardan shaft. But we shall soon see!
cldonley
cldonley
Robinson, TX
paul
Now I need to order the correct yoke for the D20 Along with with a new seal so that new to me shaft will bolt right up (he says, filled with hope).
