Floor Shifter but no Smooth Column Collar? No Problem!
Scoop
Have Bronco, Will Travel
Cuchara, CO
How many of you have changed over to a floor shifter and been irritated by the nub left on the collar? I have. I've hidden it with a tach, replaced it with a smooth collar from a Mustang (expensive and hard to find anymore) or just ignored and lived with it. But I decided I did not want to hide it or live with it on my 72 Patina build. So here is what I did to modify the original 3-on-the-tree collar.
First, here is the eyesore.
Since you can't weld pot metal I decided to cut off the nub and fill the resulting hole. I used a 3-inch cut off wheel to remove it.
I then ground it down smooth and used a step drill to clean up the edges of the hole.
The hole goes all the way through and I found a penny to be the perfect size to fill the hole and create a bottom for the fill.
It drove in nicely with a punch.
I guess I did "weld" it.
Then some bondo filler to smooth it out.
Can't wait to get it painted!
wsager
Nice work on that one! And I thought pennies where all but worthless these days.
Scoop
Scoop
Cuchara, CO
Here it is painted. Black primer, Black Pearl paint and 3 coats of matte clear.
Maddog B
What awesome timing! I cut mine off about 6 months ago and I’ve been procrastinating on filling it with some kind of epoxy. I looked at it today and told myself I need to work on this tomorrow.
toddz69
Nice work! I did one years ago and filled it with JB Weld and a little bondo.
Todd Z.
langester
MASTER OF MADNESS
I was just staring at my column tonight wondering what I was going to do about mine. Perfect timing on this thread, Thanks for posting it up!
JWMcCrary
Good job, and good idea. I cut it off and stuck a rubber plug in it after painting.
No Hay
Nice work Scoop!
Yes, I moved my last one to the floor and was irritated at the nub on the collar. I just cut it off flush with a sawzall and glued a plastic cap over the hole. Your result is much nicer!
Scoop
Scoop
Cuchara, CO
Here is the collar and wheel installed.
Thanks for all the positive comments!!
bfoldy
Torrance, CA
Nice work! Seems like a good approach and came out looking clean.
Sorry to stray, but I noticed you have a Hobart 140 welder. How do you like it? I’m thinking about getting that one for my first welder.
Scoop
Scoop
Cuchara, CO
I love the Hobart but it's a 210. It can use both 220V and 110V. But the 140 would be great starter welder especially for sheet metal work.
