joshd1971bronco
I’m in the market for a new pickup. This pickup will be used as a somewhat daily driver around town (when I’m not driving the bronco locally) as well as the tow vehicle for my bronco up to the Colorado Rockies (from Oklahoma) one or two times per year.
My dilemma – ½ ton gas burner or ¾ ton turbodiesel?
Obviously the ¾ ton turbo diesel will pull my 5000lb (?) bronco on a 1500lb (?) trailer with an additional 1000lbs of gear and people the best, fastest, and easiest. BUTTTT, as I’m sure you know, ¾ ton turbodiesels cost MUCH more than a ½ ton and you sacrifice ride quality (when unloaded), maintenance expense, fuel expense, and on and on.
Question – will today’s ½ ton crew cab 4x4 pickups with a large v8 gas burner (think Ram 1500 or F-150) tow a bronco on a trailer sufficiently up to the mountains? Most max trailer weights for a ½ ton truck like this are in the 7500lb – 9000lb range and I’d be right at it I think. Am I asking for trouble (blown transmissions, engines, etc) or am I just going to be a little slower up and down the hills with a 1/2 ton? Should I upgrade to the 3/4 ton and live with the sacrifices when not towing?
Again, I’ll only be towing a heavy loaded trailer like this a couple times a year and the rest of the time I’ll be driving back and forth to work and the grocery store. I’d be interested to hear anyone’s opinion on towing with a ½ ton vs ¾ ton and living with the same pickup the rest of the year.
