needabronco
Just because your trailer is rated for 12K pounds, doesn't mean the truck is. Just because the truck can actually haul it doesn't mean it's rated for that much weight. And Yes, I've hauled more weight than my truck is rated for also, but it was in an extenuating circumstance.
Keep this in mind. If your truck is rated for 7K pounds and your hauling 7500 and you are in an accident, if the officer investigating figures out that your load was overweight YOU will be found liable for the accident regardless of who's at fault. AND your insurance company will most likely NOT cover you because your load was overweight....
I did a quick search, assuming your truck is an extended cab;
To have the 3.42 gears you must have a 4.6 liter V8, if so you can tow 5500#
If you have the 5.3 liter and 4.10's you can haul 8500#, 3.73's would tow 7500#
According to the list I was referring to if you have a 2wd and a 5.3 you can have the 3.42 gears, and that combo can tow 6700#
