10 Gauge is way too small for the amp load your going to put on it especially from the battery to ground
I love 1/0 cable ;D
I love 1/0 too. Great stuff.
But he was asking just about the auxiliary grounding stuff. Engine to body, battery to body, stuff like that. Sounds like he's already using a standard ground cable from the battery to the engine.
For that, I'm in agreement with the others. The 10 would be ok for most things, but Viper stated a good reason the factories use exposed braided straps whenever feasible. Long term reliability.
When it comes right down to it though, 10 would be fine with your stock, or near stock loads, since that's what's commonly used in the factory EB and the aftermarket stuff too.
Just look at some replacement battery ground cables and you can find 10 gauge pigtails for the body connection quite common.
And the wire that feeds the in-cab components and accessories on stock EB
AND aftermarket harnesses is mostly 10 gauge. Pretty sure that Centech and Painless both use 10 gauge wire to feed all the junk in the cab, so a couple of 10ga aux grounds would be appropriate. Where appropriate.
But braided straps are cheap and already come pre-terminated with ring terminals crimped and soldered in place. Easy peasy, nice looking and reliable as stones.
Worth a look at least Audog
