I want to gain more clearance around the tie rod ends after installing the F150 knuckles for disc brakes. I have seen both 16 and 17 inch rims steel rims available, with prices as low as $60-70 each on Ebay and Amazon, but are they any good in terms of being concentric and balanced? More expensive ones are $100 and up. Being on a budget I don't want to spend more than needed.
It appears that the center should be ~3.35 or 85mm but I notice some rims have a much larger center bore. If rims with larger bores are used should I find a concentric ring to install? The back spacing on the rims I have seen run between 3.75 and 4.03 inches. Most of the rims I have seen with 5 on 5.5 have been 8 or 9 inches wide.
My Bronco has a 2.5" suspension lift and 2" body lift. Would a 265/75R16 (or 17) be a reasonable tire size to run without rubbing? Or bigger or smaller tires?
Any comments would be welcomed! Thanks!
