1970 1/2 cab build "phase 2"
Ether
Ether
Tulsa
Amazon delivered the DOM
Ether
Ether
Tulsa
Curious: Why did you decide to axe the Snpier?
Well, I stumbled on a Pro-flo 4 for a good price, my intake had some coolant runner degrading, I was planning on running a HEI and not controlling spark. Also kept hearing stories of RFI and other issues with running sniper on SBF's.
Ether
Ether
Tulsa
Did some planning, removed all old body mounts and installed WH 1” body lift/mounts.
Sawzall + large pry bar + lots of ugga duggas
I’m spent, also removed the stock front shock mounts.
Ether
Ether
Tulsa
Didn’t make it back out to the shop today, but removed the intake off my 5.0 and put on the
Edelbrock Pro-Flo, not sure if that breather will work with a 1” body lift…
Nice. Are you going to be running a heater? Is there a boss on the intake for the heater hose fitting?
Ether
Ether
Tulsa
Putting my cam specs here for documentation.
77Bronco636
Nice build…you keeping the paint the way it is (I like it)…..what air breather is that? Id like to see if I can fit one on my truck, I like it!!
Ether
Ether
Tulsa
Yeah paint will stay as is, at least for this phase.
It's a Holley product, dual breather 64280
Ether
Ether
Tulsa
I have no idea if it will fit my 5.0 with Pro Flo and 1" body lift.
Ether
Ether
Tulsa
Test fit of the rear 3.5 WH springs, and test install of the SSBC D30 Disc conversion I picked up a while back.
Not 100% sure on caliper orientation but couldn’t get them to clear any other way. Still had to massage the caliper and knuckle with a grinder as pictured.
Oldtimer
Jr. Member with Sr. moments
Sunnyvale, CA
Can you swap calipers left to right?
Gonna be tough bleeding them with bleeders lower than pistons.
Ether
Ether
Tulsa
Turns out I had them clocked incorrectly, they go at almost 3 oclock and swap to the other side.
But….packed the bronco up to bring her home and the wheels don’t clear. Removed calipers for now, I’ll have to figure that out.
Decided to slap the axles under it and bring it home. I’ve been renting this shop space for almost 2 yrs but progress has been slow. Packing it up and bringing it into my garage to hopefully get it back on the road sooner than later! Out of sight, out of mind.
As it sits: no engine/trans, 3.5” WH leaf pack, mystery progressive coils, stock radius arms.
