aaron6920
Hi Aaron,
The pass side quarter is just sitting in place, I still have a lot of metal prep to do first before welding it on. On the drivers side I drilled holes from the inside of the truck to the top of the quarter, and spotwelded down from the upper rocker, also using sheet metal screws about every 2" to hold the quarter in place. In the rear I set the quarter in place, clamped it down, and then drilled holes from the inside of the wheel well through the quarter but not into the tail light box. Then I welded both panels through to the tail light box. In the front rocker, after welding the quarter into the door jamb I drilled holes through the quarter and welded the rocker onto the quarter through the wheel well side. I'll get some more desriptive pictures taken as I go along on the pass side. I also will be replacing the entire rocker on the pass side. Thanks for asking!
Bernie
Looking forward to more pics
