I was disappointed when I first saw the engine bay. I was hoping it would look brand new. It's not until you start looking at small details that you appreciate how it looks after all those years of Midwest weather. The engine bay is essentially as found with no real detailing done. As you can see various components took a beating from the weather while others remain in good condition.The air cleaner is a good example. The top looks weathered but underneath is pristine.
More from Andrew's report:
"It is reported that the Bronco was purchased and used for only a couple months before being put into
storage. Also the car was carefully broken in. The owner was particular about break-in maintenance and kept
speeds low. This is evidenced by the radiator fins - there is no debris in the fins, no bugs, no small rocks. The
fins are also arrow straight suggesting this car was not driven at high speeds or on any sort of long trips. The
under 500 miles on the odometer were probably put on in-town.
Engine items like the spark plugs, wires and vacuum hoses are all original pieces."
