Proeliator
- Dec 15, 2005
- 32
So, I abruptly lost the majority of my brake ability the other day. Factory drum brakes all the way around. After pulling the wheels and drums off, I found I have no leaks at the wheel cylinders (or the master cylinder for that matter), and most oddly there seems to be zero pressure reaching the front brakes only. System has been bled, and the pedal is solid.
All I can think of is that something failed in the master cylinder (clogged?) which caused this. I did notice something that looks like a proportioning valve downstream from the master cylinder with an electrical connection running to it. My understanding is that only disk/drum setups utilize proportioning valves, so I'm thinking this must just be some sort of distribution block, although for the life of me I can't imagine what the electrical connection running to it could be. So, this could be a culprit for a clog/failure as well since the rear brakes work and both fronts have no pressure. Just wondering what the heck this is and figured you guys would know.
Honestly, I'm seriously thinking about springing for the power front disc brake conversion that TBP sells at this point. Just curious what you guys think about the failure issue and what the heck exactly the deal is with the distribution block/proportioning valve/whatever the heck it is with the electrical connection.
Thanks in advance.
Thanks in advance.
