1989 Ford 302 roller motor
Buckey
Dayton, Texas
I have a 1974 Bronco I am currently Building a 1989 ford 302 roller motor for it and trying to find out what balancer and flex plate I should use for this motor when I bought the motor it did not have either with it. The casting number for the crank shaft is E7AE-AA The block casting is E7TE
Viperwolf1
electron whisperer
You need a 50 oz-in balancer and flexplate. The old '74 302 will have 28 oz-in pieces.
B
Buckey
Dayton, Texas
Thanks Viperwolf1 I was told that this motor was internally balanced. does that sound right to you and would that be why it has to be a 50 oz-in balance and were can I get the balancer with three bolt hole for my V belt pulley and the flex plate? I just want to make sure everything is right before I fire it up.
Viperwolf1
electron whisperer
Who is telling you this? Internally balanced generally means enough weight is added to the crankshaft to keep the balancer and flexplate at zero imbalance. This would have to de done by a machine shop with the engine disassembled. Not very common for a SBF.
B
Buckey
Dayton, Texas
I bought the short block through Craig's list. The guy I bought it from told me that he had bought the motor from a machine shop a short time ago, he was changing to a 347. This motor has a stock crank and rods with Essex Pistons so he says. The crank does not look like anything has been added to it. The casting mark on the crank says E7AE-AA I am not sure he knows what he is talking about when he says it is Internally balanced. I just want to make sure I use the correct parts when I put it back together.
ransil
Buy a flex plate for a 92 Mustang 5.0L automatic.
I had my Bronco balancer re-balanced by a machine shop when I used the Bronco front accessories, better option is to use a serpentine accessories and a 5.0L balancer.
mcdobson
Sacramento
Look at the crank or post a picture. If there is no heavy metal welded into a counter weight or a counter weight drilled like swiss cheese, then it is not zero balanced and will take the 50oz pieces.
B
Buckey
Dayton, Texas
I am sot sure how to post a pic but this was all I could find I have some pics of the bottom end in my Photo Gallery.
27532
B
Buckey
Dayton, Texas
1989 Ford 302
Thanks for every one that helped. I think I agree from all the research and all the answers you guys have giving this has to be 50 OZ in-balance
