Faster Eddie
So, we rebuilt my original 72 302 block using the same crankshaft. Other than that, everything is new. Fired it up and had oil leak coming out of the bell housing.
Have replaced the rear main (2 piece) a couple times now. Seems to be the lower half that gives out. Have used the black $8.00 seal.
Next steps: stick a feeler gauge in the crank to see if I have too much play. Buy the $26 high performance (brown) 2 piece seal and shove that in with some anaerobic sealant.
Thought about speedy sleeve but sounds like you can't use them with a 2 part seal.
There's an engine close by with a 1980 lower end rebuilt 2000 miles ago.
Question: can or should I take all my nice new stuff out of my 302 and drop it all into this new (old) 1980 block?
Should I use the crank, flywheel and balancer from the 1980 or use my current crank, f-wheel and balancer?
Wide open to help. Thanks guys!!
