Does yours look like that, with a knob showing that pattern?
What year is your bronco? The official start of automatic transmissions from the factory was 73, but some late 72s might have come that way. Anything earlier than that and the transmission was swapped in by a previous owner.
The transfer case shift pattern also changed about the same time. The earlier T-shift is a linear forward and backward pattern. Where four low is up towards the dash.
The J shift as shown in the picture was 73 and later. Four low is the same forward position, but as you can see, 2-high is over and up.
