DrDanWWW
- Joined
- Apr 7, 2019
- Messages
- 68
I have an 1983 EIBE 200ci engine (Fairmont) I am thinking of swapping for my 170ci. The '83 has the lower starter. And although I don't have the bell housing, it looks like it takes the Big Bell, the same as used for the 289, 302, 351 V8s. Correct?
Question: What I really want to know is this: does the shifter come through at the same place as the 3 spd? Is the trans mount at the same location on the frame?
I know I need the Big Bell, clutch, and flywheel (how many teeth?). It looks like the output shaft is an inch longer. Do you swap the output shaft, or not if you're using the Bronco trans to Dana 20 adaptor? Currently I have a Hurst 3 spd shifter. I will need a different shifter for the 4 spd. But is the shifter in the same general location as the 3 spd, with similar style of linkage? How drastic do I have to modify the tunnel? Then there's the this thing about drilling out for the larger bearing. What exactly is that?
The Classic Bronco Tech Article on Manual Trans says...
Bell housing:
Standard Ford. The Toploader will bolt up to your existing bell housing on small block (289-302-351) engines. The existing Bronco clutch is also used. But "existing" for what? The 289 V8 clutch?
Modifications needed:
The entire assembly is 1″ longer than a stock 8 cyl Bronco transmission [what is "stock?"], so drive shaft modifications may be necessary depending on the amount of suspension lift you have. The stock Bronco 8 cylinder intermediate housing needs to be machined for the larger Toploader bearing and drilled to accept the shift rail. You’ll also need to cut a hole in the floor for the side shifter. A four speed floor shifter needs to be installed, requiring some floor board cutting.
I am getting excellent help from Bubba22389... but I thought I'd throw this out there to the rest of the forum. "Wisdom's many friends..."
Bell housing:
