302 cam choice?
The 351w will have a ridge about an inch tall behind the distributor location.
Basically the china rail (where the leading edge of the intake manifold sits on the block) is taller on a 351 than the 302/5.0 so you can see at a glance if it's the taller block of the 351.
Sounds like you may have an aftermarket block perhaps? I'm not up on my numbering either, but find it odd that there are no identifiers near the starter.
Be very cool if it's a 351 though.
la hi
la hi
I apologize!!!
To all of those who said every block has an ID number and I said NO mine does not. I apologize. The block number is right where you said it was--above the starter. When I turned the block upside down I found it.
E3AE 6015 BA20 and a 4031 stamped under the number.
Please help decode it.
E =80's
3=83
A=full size ford
E=engine??
6015 is the part number
B=?
A=?
20 =?
What do you belive it means?
