- Mar 21, 2024
- 262
I just replaced the points and am learning how to properly set base and total timing. I did not remove my distributer when changing the points and used a feeler gauge to gap, I believe it was about .021. Since my dwell changed as a result I would assume timing will be a bit off from before. I am utilizing a dual port distributer vacuum advance (just replaced and I believe it is working correctly as the engine idle drops when I plug the top vacuum advance port). My vacuum lines are set-up true to stock for a 1970 (August 1969, New York DSO). I have an original, Autolite 2100 2b just rebuilt.
I purchased an Innova digital timing gun with tach.
Can someone please, in layman terms, provide me the step by step instructions to set my timing. I have very solid compression for my stock/original 302. I know base timing without advance should be about 6-8 degrees as a start for base.
This is how I am going about it. Am I doing everything correctly?:
1. Connect timing gun to battery & 1 cylinder spark plug wire (passenger side, first one).
2. Start Bronco and let it warm to operating temperature. Double tap to step down to idle to normal idle. I believe idle for a 303 manual transmission should be about 650 rpm.
3. Remove both vacuum lines from the vacuum advance (top port and front port) and plug both.
4. Point timing gun at the balancer. My balance is quite rusted, its hard to read. My mechanic put a white line, I believe he said that should mark about 8-12 degrees BTDC. If i need to advance or retard, loosen distributer screw and turns while engine is running clock (advance) or counter clock wise (retard)
5. Reconnect vacuum lines, hold idle on carb in the 3000-3500 RPM range. Advance should be in the mid 30s range.
Here is my issue, on my timing gun, the white line on my balancer and pointer on the block line up when I set my timing gun to 16 degrees. This is with the vacuum advance plugged (both tubes or even just one at a time), and with the vacuum advance hooked up). The degrees advanced does not change just the idle (decreases) when I plug the advance. My base idle based on the timing gun (my only tach) seems high, I believe between mid 800's and mid 900's depending on if advance is plugged.
Should I adjust my idle down on the carb before retarding my timing (by adjusting the distributer screw) to get a more accurate read on the base timing degrees? Do I plug the top, front or both vacuum lines on the advance? Will I hurt the engine by driving temporarily as is? I really need the Bronco this week. I have taken for a couple of rides and it seems to be running smoothly. I dont believe I have any knock, which would make sense since my timing seems low. Uploaded a video for visuals.
Video Link
Thank you!
Video Link
Thank you!
