If you are in touch with the fact that in going 35 sp you will have to replace the case and the locker/spool the total build cost wetween going 35 or 31 is only something like $200 on $1200 worth of parts. If I were starting from scratch, upgrading from 28 spline, its a no-brainer. But if I already had a 31 spline Detroit locker, I'd have to get decent money for the used Detroit locker to consider not upgrading to the 35 spline everything.
BTW, Summit Racing a few years ago had the sweet deal on Strange Engineering "econo nodular" cases. They are only a few times stronger than the factory Ford nodular cases (which are far stronger than the standard Ford cases) but in my opinion they are pleanty strong enough. They are in the mid $200 range delivered to your door. Food for thought when you are going to be looking at nodular cases in the $450+ range anywhere else.
Dan
